How add EditAccounts permission for my Application amocrmTest?
How add EditAccounts permission for my Application?
If your application is still in the sandbox, simply login your account and select the app from your App list then select "Settings" and change (add or remove permissions) the "Permissions Needed".
If your application is already graduated to the production. You need to clone the app and add the new permission. Test your app then graduate the new app.
+ Phong
+ Phong
