How do I do a call transfer using RC phone API?
  • 2 July 2018
  • 303 views
How do I do a call transfer (blind or warm) to another extension RC phone APIs?
From my initial research I see that this functionality may not be available yet via API, but I was wondering if anyone found a solution to this problem?
I believe you can do it with WebRTC: https://github.com/ringcentral/ringcentral-web-phone#transfer
Another option is to using RC's Call control API which is still internal beta, so you have to wait.
