Now that I've got the voicemail body using the ringcentral-pubnub library, how do I use the java SDK to get the voicemail transcription via the URI in the attachments?
How do I get the voicemail transcription using java SDK?
Provided that you are using the RingCentral Java SDK, you can read the transcript file as shown below.
public void read_message_store_voicemail() throws RestException, IOException{ ListMessagesParameters parameters = new ListMessagesParameters(); parameters.messageType = new String[] {"VoiceMail"}; var response = restClient.restapi().account().extension().messagestore().list(parameters); for (GetMessageInfoResponse record : response.records) { if (record.attachments != null) { for (var attachment : record.attachments) { var fileName = "./src/test/resources/" + record.attachments[0].id + "_voicemail.txt"; if (attachment.type.equals("AudioTranscription")) { var res = restClient.restapi().account().extension().messagestore(record.id).content(attachment.id).get(); Path path = Paths.get(fileName); Files.write(path, res); } } } } }
Hope this helps.
