I need Help Getting "From" using python
  • 19 June 2020
  • 249 views
I am using python to get call status on on certain extensions. If an extension has an active call I want to return the "from" number; however, Python doesn't like it when I use "from". It works for fromName but not from. It returns a syntax error.
How do I get the "from" object?
for ext in r.json().records:
exten = ext.extension.extensionNumber
for e in extensions:
if(e == exten):
extname = GetExtensions(int(exten))
status = ext.telephonyStatus
if(status != "NoCall"):
for a in ext.activeCalls:
print(a.from)
Userlevel 2
Badge
How about print (a['from'])
