I want integrate ringcentral with my window form. So i need to find caller number and name during phone ring from c#. So is there any possible solutions?
I want live incoming call event in c# during phone ring.
Are you using the RingCentral SDK for c-sharp? If not, open your project and install the RingCentral SDK via NuGet (search for RingCentral Client 3.0.0 package).
After adding the SDK to your project, you can use it as shown below:
using RingCentral;
const string RC_CLIENTID = "your app client id";
const string RC_CLIENTSECRET = "your app client secret;
const string RC_SERVER = "https://platform.devtest.ringcentral.com";
const string RC_USERNAME = "username";
const string RC_PASSWORD = "password";
const string RC_EXTENSION = "extension number";
RestClient rc = null;
SubscriptionService subscription = null;
protected void Page_Load(object sender, EventArgs args)
if (rc == null)
rc = new RestClient(RC_CLIENTID, RC_CLIENTSECRET, false);
RegisterAsyncTask(new PageAsyncTask(RingCentralAuthenticationAsync));
private async Task RingCentralAuthenticationAsync()
await rc.Authorize(RC_USERNAME, RC_EXTENSION, RC_PASSWORD);
if (rc.token.access_token.Length > 0)
Console.WriteLine("Authorized");
RegisterAsyncTask(new PageAsyncTask(subscribeForNotification));
private async Task subscribeForNotification()
subscription = rc.Restapi().Subscription().New();
subscription.EventFilters.Add("/restapi/v1.0/account/~/extension/~/incoming-call-pickup");
subscription.NotificationEvent += (sender, args) =>
var message = args.message;
Console.WriteLine(message);
subscription.StatusEvent += (sender, args) =>
Console.WriteLine(args.Message);
await subscription.Register();
Check out other notification type. Particularly the "Presence" would give you better telephony status.
Hope this helps!
+ Phong
using RingCentral;
if (rc == null)
Hope this helps!
+ Phong
We implemented as you mentioned before.
But main aim is :
I have installed ringcentral windows client . When call comes to my number i want find incoming call event in c# and want to place my stuff in that event and i want operate phone from screen(answer call, end call).And also i want know ring central supports TAPI?
But main aim is :
