ImportError: No module named observable in python test SMS,ImportError: No module named observable for SMS quick start
  • 27 March 2021
  • 5 replies
  • 935 views
I believe there is missing a folder and file (s) in the RingCentral directory of Github for the Python SDK. I follow this tutorial (SMS Quick Start): https://developers.ringcentral.com/guide/messaging/quick-start#python
I follow the steps outlined:
I am creating an app. Everything is fine.
I am importing the Python RingCentral DSK. Everything is fine.
I create and edit my sms.py file. There too all is well.
But when I run my sms.py file, I get this error message (last line):
ME-python-sdk% python sms.py
Traceback (most recent call last):
File "sms.py", line 1, in <module>
from ringcentral import SDK
File "/Users/ME/ringcentral-python-sdk/ringcentral/__init__.py", line 4, in <module>
from .sdk import SDK
File "/Users/ME/ringcentral-python-sdk/ringcentral/sdk.py", line 4, in <module>
from .platform import Platform
File "/Users/ME/ringcentral-python-sdk/ringcentral/platform/__init__.py", line 5, in <module>
File "/Users/ME/ringcentral-python-sdk/ringcentral/platform/platform.py", line 5, in <module>
from observable import Observable
Indeed there is no Observable file / folder
But I believe there is missing a folder and file (s) in the RingCentral directory of Github for the Python SDK. I follow this tutorial (SMS Quick Start): https://developers.ringcentral.com/guide/messaging/quick-start#python
ringcentral-python-sdk % python sms.py
Based on your "ImportError: No module named observable" , can you please check this similar installation issue :
https://community.ringcentral.com/questions/7978/ringcentral-import-error-in-python.html
also you can refer: https://github.com/ringcentral/ringcentral-python to start with.
Hope that help
Hi !Thanks but it still does not work.
ME@vincent ringcentral-python-sdk % python3 ringout.py
File "/Users/ME/ringcentral-python-sdk/ringcentral/http/client.py", line 28, in send
response.response().raise_for_status()
File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/requests/models.py", line 943, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 400 Client Error: Bad Request for url: https://platform.devtest.ringcentral.com/restapi/oauth/token
During handling of the above exception, another exception occurred:
File "/Users/ME/ringcentral-python-sdk/ringout.py", line 15, in <module>
platform.login(RINGCENTRAL_USERNAME, RINGCENTRAL_EXTENSION, RINGCENTRAL_PASSWORD)
File "/Users/ME/ringcentral-python-sdk/ringcentral/platform/platform.py", line 106, in login
raise e
File "/Users/ME/ringcentral-python-sdk/ringcentral/platform/platform.py", line 100, in login
response = self._request_token(TOKEN_ENDPOINT, body=body)
File "/Users/ME/ringcentral-python-sdk/ringcentral/platform/platform.py", line 173, in _request_token
return self.send_request(request, skip_auth_check=True)
File "/Users/ME/ringcentral-python-sdk/ringcentral/platform/platform.py", line 149, in send_request
return self._client.send(self.inflate_request(request, skip_auth_check=skip_auth_check))
File "/Users/ME/ringcentral-python-sdk/ringcentral/http/client.py", line 34, in send
raise ApiException(response, e)
ringcentral.http.api_exception.ApiException: Invalid resource owner credentials
I guess this is a credential issue ?
Userlevel 2
Badge
Your first problem and second problem are completely different. Don't say "...Thanks but it still does not work."
Your first problem was the "Observable" module was not installed. Simply install the missing lib and try again.
Your second problem is purely about wrong username/password. All you need is to make sure the username, password and extension number (if specified) must be correct. One way to check is to login your account service web (remove the "devtest" if login your production account). If you can login that page with the user credentials, you should be able to login your app using the same credentials.
Thanks Phong Vu for underlying the two different errors. I did not understand those, hence my previous answer. Of course If i understood I would not have written this answer.
This is clear now, i understand what the problems are. I'll follow your advice to log with the user credentials. I am looking for the library 'Observable', is it in https://github.com/ringcentral/ringcentral-python ? I am unable to locate it.
Thanks Anirban, i succeeded in running the demo described here https://github.com/grokify/ringcentral-demos-oauth/tree/master/python-bottle until I click on the button on the web page
RingCentral 3-Legged OAuth Demo in Python,
then I have this message : did i miss something ? Thanks in advance
  "error" : "invalid_client",
  "errors" : [ {
    "errorCode" : "OAU-113",
    "message" : "No redirect uri is registered for the client"
  "error_description" : "No redirect uri is registered for the client"
