JWT: error Error: Client authentication is required | Node SDK
  • 20 October 2023
  • 189 views
Using this code to try and authenticate the SDK.
import { SDK } from "@ringcentral/sdk";
export default async function fetchRingCentralData() {
  const rcsdk = new SDK({
    server: process.env.RC_SERVER,
    appKey: process.env.RC_CLIENTID,
    appSecret: process.env.RC_CLIENTSECRET,
  const platform = rcsdk.platform();
  await platform.login({ jwt: process.env.RC_JWT });
Receiving error
The app is set up as a JWT app.
Can someone help?
Userlevel 2
Badge
The new SDK constructor takes new param object.
    clientId: process.env.RC_CLIENTID,
    clientSecret: process.env.RC_CLIENTSECRET,
Can you share the link to the documentation or sample code that shows you the old code. We will fix the documentation accordingly. Thanks.
That worked, thank you. I probably pulled that from some other community post's code when debugging something else. Could've sworn I tested what was in the docs, but apparently not. Docs all appear correct.
Oh wait, it's in the test data here - https://developers.ringcentral.com/api-reference/provisioningcleanshot-2023-10-20-at-173932.png
