Permission Issue
  • 5 February 2021
  • 884 views
So I created 2 little applications to 1) read data from the logfiles and 2) to get a list of users.
The first one is working fine using the API
The second one returns
  "errorCode" : "InsufficientPermissions",
  "message" : "In order to call this API endpoint, application needs to have eReadAccounts] permission",
  "errors" : {
    "errorCode" : "CMN-401",
    "message" : "In order to call this API endpoint, application needs to have oReadAccounts] permission",
    "permissionName" : "ReadAccounts"
I have tried all the possible permissions, including Read Accounts, with no luck. I even gave the app every permission available. Still the same.
Any ideas?
Userlevel 2
Badge
What API call returned that error?
https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/directory/entries
and even if I gave the app every permission, I was getting the same response.
Ok there is clearly something up. Created app #3 with the same authorization and that works.
I think if you update the authorization after you create the app, that is not working at RingCentral
