PHP SDK Issue - Uncaught Error: Call to a member function post() on null
  • 26 April 2023
  • 223 views
Probably a dumb issue, I'm used to C# and Python but not PHP, trying to move an automation I have over to PHP.
Not sure what I'm doing wrong here, but every time I run the below code, then test it, I receive "Uncaught Error: Call to a member function post() on null in /path/to/myapp.php"
<?php
require('vendor/autoload.php');
use RingCentralSDKSubscriptionEventsNotificationEvent;
use RingCentralSDKSubscriptionSubscription;
$RINGCENTRAL_CLIENTID = 'sensored';
$RINGCENTRAL_CLIENTSECRET = 'sensored';
$RINGCENTRAL_SERVER = 'https://platform.ringcentral.com';
$RINGCENTRAL_USERNAME = "sensored";
$RINGCENTRAL_PASSWORD = 'sensored';
$RINGCENTRAL_EXTENSION = "sensored";
$platform->login($RINGCENTRAL_USERNAME, $RINGCENTRAL_EXTENSION, $RINGCENTRAL_PASSWORD);
$subscription = $rcsdk->createSubscription();
$subscription->addEvents(array('/restapi/v1.0/account/~/telephony/sessions'));
$subscription->addListener(Subscription::EVENT_NOTIFICATION, function (NotificationEvent $e) {
if(($e->payload()['body']["parties"][0]['to']['phoneNumber'] == 'myextension') or ($e->payload()['body']["parties"][0]['to']['phoneNumber'] == 'myDID') and ($e->payload()['body']['parties'][0]['status']['code'] == 'Setup'))
$accountId = '~';
$telephonySessionId = $e->payload()['body']['telephonySessionId'];
$partyId = $e->payload()['body']['parties'][0]['id'];
$body = array(
'extensionNumber' => 'sensored'
$r = $platform->post("/restapi/v1.0/account/{$accountId}/telephony/sessions/{$telephonySessionId}/parties/{$partyId}/forward", $body);
echo json_decode($r);
$subscription->setKeepPolling(true);
$subscription->register();
I've verified that the variables are all good, URL is pulled properly, and that I'm sending the required params as seen here: https://developers.ringcentral.com/api-reference/Call-Control/transferCallParty
Is it because I'm calling this from inside of the event notification?
Any help would be appreciated, especially on the proper way of doing this
Full error:
PHP Warning:  Undefined variable $platform in myapp.php on line 31
PHP Fatal error: Uncaught Error: Call to a member function post() on null in myapp.php:31
Stack trace:
#0 /sensored/vendor/symfony/event-dispatcher/EventDispatcher.php(184): {closure}()
#1 /sensored/vendor/symfony/event-dispatcher/EventDispatcher.php(46): SymfonyComponentEventDispatcherEventDispatcher->doDispatch()
#2 /sensored/vendor/ringcentral/ringcentral-php/src/Subscription/Subscription.php(276): SymfonyComponentEventDispatcherEventDispatcher->dispatch()
#3 /sensored/vendor/pubnub/pubnub/composer/lib/Pubnub/Pubnub.php(565): RingCentralSDKSubscriptionSubscription->notify()
#4 /sensored/vendor/pubnub/pubnub/composer/lib/Pubnub/Pubnub.php(375): PubnubPubnub->_subscribe()
#5 /sensored/vendor/ringcentral/ringcentral-php/src/Subscription/Subscription.php(252): PubnubPubnub->subscribe()
#6 /sensored/vendor/ringcentral/ringcentral-php/src/Subscription/Subscription.php(129): RingCentralSDKSubscriptionSubscription->subscribeAtPubnub()
#7 /sensored/vendor/ringcentral/ringcentral-php/src/Subscription/Subscription.php(86): RingCentralSDKSubscriptionSubscription->subscribe()
#8 /sensored/myapp.php(36): RingCentralSDKSubscriptionSubscription->register()
#9 {main}
thrown in /sensored/myapp.php on line 31
(31 is:)
Userlevel 2
Badge
If you want to use a global variable inside a PHP function, you have to redeclare it with the global keyword inside the function before using it. So try this:
    global $platform;
        $accountId = '~';
        $body = array(
