5+ API calls per each used endpoint requirement not met
  • March 1, 2023
  • 187 views
The "5+ API calls per each used endpoint" is flagged as not met even though I have 12 calls for both endpoints (24 total) over the last two days. What do I need to do in order to be eligible for graduation?
Sandbox Client ID: 2Kq8PHk-TG6mZ227yNCdcA
  • March 2, 2023
I am so sorry for the difficulty you experienced. I looked into your application's statistics and it appears you met all the criteria for graduation. Therefore, your app has been granted production credentials. I am going to reach out to engineering to investigate why this wasn't done automatically.
