Amateur - Looking for solution to un-removable attendees from Meetings
  • July 31, 2019
  • 1971 views
In meetings, sometimes when there is an attendee that is not supposed to be in the meeting, and you try to remove them, they are unremovable.
I have seen before where a code/script was developed the forced removed an attendee.
(Even if they were a cohost & you were a cohost.) *Only a host should be able to remove a co-host*
I'm not sure if the script un-cohosted the user first, then removed, or just brute force removed. I do know the user saw the pop up saying the HOST removed them.
  • August 1, 2019
I am not aware of any API available for removing meeting attendee. So it is not possible to achieve this programmatically.
This a good option actually.. why not you raise an Idea request on this?. Maybe the RC team can explore the idea and consider it with some more modification and implement that
Yes, There is no API exposed by RC team to remove meeting attendee as of now. RC team has to build API for this :). Good question by Adam.
