Authorize takes forever with password flow
  • May 9, 2019
  • 1224 views
Hey
I use nuget RingCentral.Net to connect to API and Password flow with sandbox Server only platform
When I connect with console application with the following code I succeed (get token and get call logs)
var rc = new RestClient(Config.Instance.clientId, Config.Instance.clientSecret, Config.Instance.server);
var token = rc.Authorize(Config.Instance.username, Config.Instance.extension, Config.Instance.password).Result;
When I try to connect to api with an application (ASP.NET MVC) that is on IIS the authorize takes forever, without exception
Hi, it might be deadlock issue.
And it is a common C# async programming issue: https://medium.com/rubrikkgroup/understanding-async-avoiding-deadlocks-e41f8f2c6f5d
In short, do not mixed async code and sync code.  If your app is async overall, you should not use .Result.
Thanks, call log work perfect but when i want to send sms like
static async Task Main(string[] args)
using (var rc = await Login()) { await SendSms(rc); } }
private static async Task<RestClient> Login()
    var rc = new RestClient("***", "*********", "https://platform.devtest.ringcentral.com/");
    await rc.Authorize("+*****", "101", "*****");
    return rc;
} public static async Task SendSms(RestClient rc)
    var sms = new CreateSMSMessage()
        @from = new MessageStoreCallerInfoRequest() { phoneNumber = "+****" },
        to = new[] { new MessageStoreCallerInfoRequest() { phoneNumber = "+****" }, },
        text = "test yaacov"
     var resTask = await rc.Restapi().Account().Extension("101").Sms().Post(sms);
The Authorize return token but post sms get exception
System.ObjectDisposedException: 'Cannot access a disposed object.
Object name: 'System.Net.Http.StringContent'.'
When i run same details with Api reference "try it out" button it work fine
