Basic C# example not working.
  • February 17, 2022
  • 9 replies
  • 556 views
Hello, first time user here. I'm trying to test the most basic code sample for C# but it isn't working and it's throwing a very vague exception. Code and exception below. I replaced the sensitive variables with comments describing what they had been set to.
using System;
using System.Threading.Tasks;
using RingCentral;
using DotNetEnv;
namespace Call_Ringout
    class Program
        static RestClient restClient;
            restClient = new RestClient(
                /*Client ID*/,
                /*Client Secret*/,
                "https://platform.devtest.ringcentral.com");
            restClient.Authorize(
                /*Username*/,
                /*Extension*/,
                /*Password*/;
            call_ringout().Wait();
        static private async Task call_ringout()
            var parameters = new MakeRingOutRequest();
            parameters.from = new MakeRingOutCallerInfoRequestFrom
                phoneNumber = /*From Number*/
            parameters.to = new MakeRingOutCallerInfoRequestTo
                phoneNumber = /*To Number*/
            parameters.callerId = new MakeRingOutCallerInfoRequestTo
                phoneNumber = /From Number/
            parameters.country = new MakeRingOutCoutryInfo
                id = "1"
            parameters.playPrompt = false;
            //var resp = await restClient.Restapi().Account().Extension().RingOut().Post(parameters);
            //Console.WriteLine("Call Placed. Call status" + resp.status.callStatus);
            var _1 = restClient.Restapi();
            var _2 = _1.Account();
            var _3 = _2.Extension();
            var _4 = _3.RingOut();
            try
                var resp = await _4.Post(parameters);
            catch(Exception e)
                Console.WriteLine(e.InnerException);
                Console.WriteLine(e.Message);
                Console.WriteLine(e.ToString());
I broke up the line
Into its component parts to see where the problem is. It is in the last part, which is why I put the try block around it alone.
Here is the error I'm getting:
Object reference not set to an instance of an object.
System.NullReferenceException: Object reference not set to an instance of an object.
   at RingCentral.RestClient.Request(HttpRequestMessage httpRequestMessage, Int32 retriedTimes, Nullable`1 cancellationToken)
   at RingCentral.RestClient.Request(HttpMethod httpMethod, String endpoint, Object content, Object queryParams, Nullable`1 cancellationToken)
   at RingCentral.RestClient.Request[T](HttpMethod httpMethod, String endpoint, Object content, Object queryParams, Nullable`1 cancellationToken)
   at RingCentral.RestClient.Post[T](String endpoint, Object content, Object queryParams, Nullable`1 cancellationToken)
   at RingCentral.Paths.Restapi.Account.Extension.RingOut.Index.Post(MakeRingOutRequest makeRingOutRequest, Nullable`1 cancellationToken)
   at Call_Ringout.Program.call_ringout() in C:Userswscheffeysource
eposCall_RingoutCall_RingoutProgram.cs:line 55
C:Program Filesdotnetdotnet.exe (process 28572) exited with code 0.
To automatically close the console when debugging stops, enable Tools->Options->Debugging->Automatically close the console when debugging stops.
Press any key to close this window . . .
Any help greatly appreciated.
    Participating Frequently
    March 28, 2024
    I am having the same issue when doing a calllog, has anybody found a solution to this ?
    I don't see how you create the query params so I cannot say what could be wrong. But get the latest .NET SDK and try this code.
    using System;
    using System.IO;
    using System.Collections.Generic;
    using RingCentral;
    using Newtonsoft.Json
    namespace Read_User_CallLog
      class Program
          try
            DotEnv.Load();
            // Instantiate the SDK
                    "RC_CLIENT_ID",
                    "RC_CLIENT_SECRET",
                    "RC_SERVER_URL");
            // Authenticate a user using a personal JWT token
            await restClient.Authorize( "RC_JWT" );
            await read_user_calllog();
          catch (Exception ex)
        * Read user call log between a period of time
        static private async Task read_user_calllog()
          try
            var queryParams = new ReadUserCallLogParameters();
            queryParams.dateFrom = "2024-01-01T00:00:00.000Z";
            queryParams.dateTo = "2024-01-31T23:59:59.009Z";
            queryParams.view = "Detailed";
            var resp = await restClient.Restapi().Account().Extension().CallLog().List(queryParams);
            foreach (CallLogRecord record in resp.records)
              Console.WriteLine(JsonConvert.SerializeObject(record, Formatting.Indented));
            Console.WriteLine("Cannot read user call log data. " + ex.Message);
    March 28, 2024
    using Newtonsoft.Json;
    using RingCentral;
    using System;
        class Program
            static async Task Main(string[] args)
                try
                    RestClient restClient = new RestClient(
                        "<myclientid>",
                        "<mysecret>",
                        "https://dummy.com"
                    // I have to use ConfigureAwait instead of wait cause it will
                    //just never return with wait.
                    restClient.Authorize("<MyJWT>").ConfigureAwait(false);
                try
    Thank you for replying. My code was in a .net API. I changed it to a console app but still getting the same issue, any help would be welcome.
    You declared the static RestClient restClient in your class, then you declare a local restClient????
                        "<myclientid>",
                        "<mysecret>",
                        "https://dummy.com"
    Remove it!
                        "<myclientid>",
                        "<mysecret>",
                        "https://dummy.com"
    March 29, 2024
    I still get the same error message
    class Program
        static RestClient restClient = new RestClient(
              "<myclientid>",
                        "<mysecret>",
                        "https://dummy.com"
            try
            try
    It's not the same error. Before, the restClient was null.
    What is the reason you call the authorize this way?
    Try this to see if it helps
    await restClient.Authorize("<MyJWT>"));
    March 29, 2024
    I changed everything to be await and I am now able to get records back, however it is only returning calls I have made. I am an admin on our account. Please help me with this.
     class Program
             "<myclientid>",
             "<mysecret>", true
             try
                 await restClient.Authorize("<MyJWT>");
                 var ringCallLogResponse = await read_user_calllog();
         static private async Task<CallLogResponse> read_user_calllog()
             CallLogResponse callLog = new CallLogResponse();
             try
                 callLog = await restClient.Restapi().Account().Extension().CallLog().List(queryParams);
                 foreach (CallLogRecord record in callLog.records)
             return callLog;
    March 29, 2024
    When I run it at https://developers.ringcentral.com/api-reference/Call-Log/readCompanyCallLog. I get back 99 pages with 100 records per page.
    March 29, 2024
    I removed the .Extension() and changed ReadUserCallLogParameters to ReadCompanyCallLogParameters and it works. Thank you for you help.
