code 404 (Not Found) at c#
  • March 5, 2019
  • 2130 views
I can't get any of the API calls to answer me. it always returns as 404 Not found
Im using the nugget C# library
im using the following code
using RingCentral;
string appKey = "MYKEY";
string appSecret = "MYSECRET";
string phoneNumber = "+15178853031";
string password = "MYPASSWORD";
string country = "44";
rc = new RestClient(appKey, appSecret);
await rc.Authorize(phoneNumber, "101", password);
var tokenString = rc.token.access_token;
var extension = rc.Restapi("v1.0").Account("15178853031").Extension("101");
var requestBody = new
country = new { id = country },
from = new { phoneNumber = phoneNumber },
to = new object[] { new { phoneNumber = "+4407922204537" } },
playPrompt = "true",
var response = await extension.RingOut().Post(requestBody);
what I get is that :
Call failed with status code 404 (Not Found): POST https://platform.devtest.ringcentral.com/restapi/v1.0/account/15178853031/extension/101/ring-out
even using the API page to TRY now, returns that if i set the values for Account and Extension.
any ideas?
The issue is accountId and extensionId. If you don't know what they are, use "~" as ID. "~" means the currently authorized user.
And to get the IDs, you can rc.Restapi("v1.0").Account("~").Extension("~").Get() and check the response. ID is not number, 101 is extension number.
Do you mind trying something new?
https://medium.com/ringcentral-developers/new-ringcentral-sdk-for-net-a43417b2538c
We are going to announce it today.
It has way better exception reporting mechanism.  Try it and you will know the root cause of "{"Call failed with status code 400 (Bad Request)"
  • March 5, 2019
No solution so far, guess I will have to develop for nextiva instead.
T_T
  • March 6, 2019
Create a .Net Core app (Core 2.1) and copy paste this code and try it. It should work
using System;
using System.Threading.Tasks;
using RingCentral;
namespace Call_Ringout
    class Program
          const string RECIPIENT = "<ENTER PHONE NUMBER>";
          const string RINGCENTRAL_CLIENTID = "<ENTER CLIENT ID>";
          const string RINGCENTRAL_CLIENTSECRET = "<ENTER CLIENT SECRET>";
          const string RINGCENTRAL_USERNAME = "<YOUR ACCOUNT PHONE NUMBER>";
          const string RINGCENTRAL_PASSWORD = "<YOUR ACCOUNT PASSWORD>";
          const string RINGCENTRAL_EXTENSION = "<YOUR EXTENSION, PROBABLY ";
              call_ringout().Wait();
          static private async Task call_ringout()
              RestClient rc = new RestClient(RINGCENTRAL_CLIENTID, RINGCENTRAL_CLIENTSECRET, false);
              await rc.Authorize(RINGCENTRAL_USERNAME, RINGCENTRAL_EXTENSION, RINGCENTRAL_PASSWORD);
              if (rc.token.access_token.Length > 0)
                  var parameters = new MakeRingOutRequest();
                  parameters.from = new MakeRingOutCallerInfoRequestFrom { phoneNumber = RINGCENTRAL_USERNAME };
                  parameters.to = new MakeRingOutCallerInfoRequestTo {  phoneNumber = RECIPIENT } ;
                  parameters.playPrompt = false;
                  var resp = await rc.Restapi().Account().Extension().RingOut().Post(parameters);
                  Console.WriteLine("Call Placed. Call status" + resp.status.callStatus);
Remember to install the RingCentral SDK using NuGet package RingCentral.Client (3.0.0) SDK
Hope this helps,
