Detecting 'missed' calls for call queue members
  • June 13, 2022
  • 1703 views
Is there a way to detect if a call queue member did not answer a call when it rang their extension, even when another member answers the call?
The goal is to detect when a call comes inbound to one of our call queues, we would like to kick anyone out of the queue who has their phone ring from the queue, but does not answer the call. I've been trying to do this with event notification subscriptions, but with testing it doesn't seem to detect that the initial call queue member that received the call notification but did not answer. It simply proceeds to the next member and if they answer, the call status goes to an answered status for them.
Best answer by PhongVu
First of all, if a queue member does not pick up an incoming call, that call is not necessarily a missed call, because the call queue will ring the next members, and it can ring that member again if the queue is set "rotating".
You can detect if a member does not pick up a call by using the telephony session event notification, parse the event payload and check the the call status and reason. See the example events below:
// Member's phone ringing
    "uuid": "6532554610789882711",
    "event": "/restapi/v1.0/account/80964xxxx/extension/6229532xxxx/telephony/sessions",
    "timestamp": "2022-07-05T16:18:46.971Z",
    "subscriptionId": "54963e56-ff62-46b7-8953-18b9ee0e0b3f",
    "ownerId": "6228832xxxx",
    "body": {
      "sequence": 5,
      "sessionId": "860357227016",
      "telephonySessionId": "s-a0d7bd0254c3cz181cf282236z3cab8d40000",
      "serverId": "10.13.123.208.TAM",
      "eventTime": "2022-07-05T16:18:46.939Z",
      "parties": [
          "accountId": "80964xxxx",
          "extensionId": "62295327016",
          "id": "p-a0d7bd0254c3cz181cf282236z3cab8d40000-3",
          "direction": "Inbound",
          "to": {
            "phoneNumber": "+1209248xxxx",
            "name": "demo queue",
            "extensionId": "6249888xxxx"
          "from": {
            "phoneNumber": "+1650513xxxx",
            "name": "demo queue - SAN MATEO    CA"
          "status": {
            "code": "Proceeding",
            "rcc": false
          "queueCall": true,
          "park": {},
          "missedCall": false,
          "standAlone": false,
          "muted": false,
          "uiCallInfo": {
            "primary": {
              "type": "QueueName",
              "value": "demo queue"
            "additional": {
              "type": "CallerIdName",
              "value": "SAN MATEO    CA"
      "origin": {
        "type": "Call"
// Member did not answer the call
    "uuid": "6651780260135284845",
    "timestamp": "2022-07-05T16:19:02.018Z",
    "body": {
      "sequence": 6,
      "eventTime": "2022-07-05T16:19:01.942Z",
      "parties": [
          "extensionId": "6229532xxxx",
          "to": {
          "from": {
          "status": {
            "code": "Disconnected",
            "reason": "AgentDropped",
            "rcc": false
          "queueCall": true,
          "park": {},
          "muted": false,
          "uiCallInfo": {
            "primary": {
            "additional": {
      "origin": {
        "type": "Call"
I don't understand your use case of "kicking out queue members if they don't answer the call" though.
  • July 5, 2022
    "body": {
      "sequence": 5,
      "parties": [
          "to": {
          "from": {
          "status": {
            "rcc": false
          "queueCall": true,
          "park": {},
          "muted": false,
          "uiCallInfo": {
            "primary": {
            "additional": {
      "origin": {
        "type": "Call"
    "body": {
      "sequence": 6,
      "parties": [
          "to": {
          "from": {
          "status": {
            "rcc": false
          "queueCall": true,
          "park": {},
          "muted": false,
          "uiCallInfo": {
            "primary": {
            "additional": {
      "origin": {
        "type": "Call"
  • July 5, 2022
Thank you, I was able to figure this out after enough testing. The use case is basically we don't want agents who are missing calls sitting in our queues since they rotationally ring. It makes the customer wait longer for an agent who actually answers. I've got it figured out now and your answer is what the app is doing now.
