Error 'getStats module was not provided!'
  • June 30, 2020
  • 374 views
I am trying to make call using webRTC and this message is thrown. Do I need to import the getStats lib? If I do then why does it not mention in the ringcentral webphone documentation on github?
  • June 30, 2020
It is included in the package.json file. Did you get any error when you run $ npm install command?
"dependencies": {
    "getstats": "1.2.0",
    "sip.js": "0.13.5"
