Privacy Notice
Exporting/Decoding Call Audio With Wireshark
I'm trying to use Wireshark to diagnose VoIP quality. I can see the SIP calls just fine but cannot get it to play back the call audio. Does anyone know if it's possible to play the audio from a RingCentral call? It appears to be using the Opus codec and I see no indication that the calls are encrypted but maybe I'm overlooking something.
Login to the community
No account yet? Create an account
Login with SSO
Login with SAML2 Login with openidconnectEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
