How to get caller info (caller ID and called Nr.) from telephony presence events?
  • June 24, 2015
  • 1245 views
Whenever you want to be able to find out the Caller ID or the number being called during the progress of a call you can use this example:
var subscription = rcsdk.getSubscription();
       console.log(msg.body.activeCalls[n].from); // activeCalls is array
        console.log(msg.body.activeCalls[n].to);
    .register({
       events: ['/account/~/extension/~/presence?detailedTelephonyState=true'],
    .then(...);
  • October 1, 2015
Please can you provide an example as how I can achieve this via PHP/MySQL system.
  • July 13, 2016
TT
As I can see there is no such rcsdk.getSubscription(); method found in C# sdk . Am i missing something or Please guide me which SDk i have to use
  • July 13, 2016
TT
  • Found Your Voice
  • July 13, 2016
If you are using the C# SDK, it is recommended to ask questions pertaining to it using the Github Issue tracker for the associated repository. In the case of the C# SDK, that is here: https://github.com/ringcentral/ringcentral-csharp/issues
