is there a way to bulk delete external contacts
  • October 19, 2021
  • 373 views
I want to bulk delete contacts. I am using DELETEhttps://platform.devtest.ringcentral.com/restapi/v1.0/account/accountId/extension/extensionId/address-book/contact/contactId successfully but would like to bulk delete.
Best answer by Anirban2396911020
Yes you can delete multiple contacts using comma after each contact id
Ref: https://developers.ringcentral.com/api-reference/External-Contacts/deleteContact
Example
/restapi/v1.0/account/accountId/extension/extensionId/address-book/contact/contactId1, contactid2,…
Example
  • October 20, 2021
Perfect. that worked!
I needed to encode the comma in the URI to %2c to get it to work and found that I needed to limit the # of contacts in a single delete to 25 or so.
thanks you!
