Issue in authorization c# SDK
  • July 19, 2017
  • 5 replies
  • 959 views
Hi, i am having issue with authorization when using c# SDK. i am using below code to get access token from c#.
using RingCentral;
rc = new RestClient("appKey", "appSecret");
var tokenResponse = rc.Authorize("username", "extension", "password");
i am getting status in tokenResponse always "waitingForActivation" whether using any appKey or appSecretKey or any user name password does not matter.
every time i am getting same response in status that "waitingForActivation".
we have already install RingCentral nuget package into our project.
please help me on it
  • July 19, 2017
It should work with the following code.
await rc.Authorize("username", "extension", "password");
// get the token if you want to
var tokenString = rc.token.access_token;
+ Paco
Could you please post the full response message? (Including the HTTP status code and error message code).
It's not a NuGet issue as long as you can compile your app.
  • July 20, 2017
Above mention error got changed after applying "await" now Its giving me below error
Request to https://platform.devtest.ringcentral.com/restapi/oauth/token failed with status code 400 (Bad Request).
ErrorResponseBody :
  "error" : "unauthorized_client",
  "error_description" : "Unauthorized for this grant type"
  • July 20, 2017
It's probably because you selected a wrong platform type for your app. If you expect to login from your server code then choose the "Server-only" type. See this reference for more details about platform type (https://developer.ringcentral.com/library/getting-started.html#/#PlatformTypes)
Now you can create a new app with a correct platform type and try again.
+ Paco
You can search this forum by keyword "grant type" and check the history issues. You are not alone.
