Issue with OAUTH flow
  • January 10, 2017
  • 5 replies
  • 3557 views
I am trying to use the OAUTH flow.
I am using the AppKey as my AuthId.
I am receiving this error:
errorCode" : "TokenInvalid", "message" : "Unparseable access token",
I have been posting to the restapi/oauth/authorize address both with and without credentials. WI am using my appkey and appsecret for credentials.
This is the content I am posting:
response_type=code&client_id=beFrA7oCT5uKbmD7Da3Xiw&redirect_uri=https%3A%2F%2Floancraft.net&state=block
Any thoughts on why I am receiving this TokenInvalid message?
  • Found Your Voice
  • January 11, 2017
It means the token you are presenting to the /restapi/oauth/authorize endpoint is not in a valid format.
Here are several examples of how to use Authorization Flow in a variety of languages: https://github.com/grokify/ringcentral-demos-oauth
Also, make sure your application is set to use "Authorization Flow".
Which language are you developing with please?
You shouldn't post to /restapi/oauth/authorize, you should redirect user to that page instead. And user login RingCentral and authorize your app.   Ref: https://github.com/ringcentral/ringcentral-csharp-client/blob/master/RingCentral/RestClient.cs#L144
Once user authorized your app, the page will be redirected to your own page, where you can get an autoCode and post to /restapi/oauth/token to get access_token.  Ref: https://github.com/ringcentral/ringcentral-csharp-client/blob/master/RingCentral/RestClient.cs#L169
  • September 5, 2017
Hello
I trying to use RingCentral in my app.
So I followed http://ringcentral-api-docs.readthedocs.io/en/latest/oauth/#authorization-code-flow and I can login with RingCentral Login PopUp but popup doesn't close after login.
And Auth code is returned in PopUp Modal so I can't get the auth code in my app(main browser).
And then How can I get the access token from auth code?
I called the API(https://platform.devtest.ringcentral.com/restapi/oauth/token) with returned code but it says "error": "invalid_client".
please help me.
  • September 5, 2017
Question: So I followed http://ringcentral-api-docs.readthedocs.io/en/latest/oauth/#authorization-code-flow and I can login with RingCentral Login PopUp but popup doesn't close after login.
AK: Could you please post the redirect code that you are using? By that I mean the code where you have implemented the popup.
Question: I called the API(https://platform.devtest.ringcentral.com/restapi/oauth/token) with returned code but it says "error": "invalid_client".
AK: Could you please make sure the HTTP request headers and the Body resemble the one given here: Get Token
Steps to Authorize using the OAuth2.0
  1. Redirect the user to the Login Popup Page and once you receive the authorization code you would be redirected to your Original Page.
  2. Use the Auth Code to exchange for tokens ( access token/refresh token )  Get Token
We have a sample demo which you could refer to for:
The Authorization Code Flow, also referred to as a "3-legged authorization flow," is the most recommended approach of authenticating RingCentral users and every public apps follow this process.
It exchange to code token with access token.
Here is complete official docs with steps helps user to follow and understand the process:
https://developers.ringcentral.com/guide/authentication/auth-code-flow
Sample request:
POST /restapi/oauth/token
Accept: application/json
Content-Type: application/x-www-form-urlencoded
Authorization: Basic cmVsLWFsbC1wZXJtaXNzaWXFjMmpRZmlQcnlkSUkweE92QQ==code=U0pDMTFQMDFQQVMwMXxBQUJfTVpHWk5lM29zNVFmWnNHQ01MSmJuMHJmNGlRcnRaeEptTWlPS0MzUTdYRDdSTURiaHBuWHZINGM2WTdqaWlBOEVhRHNxRWdJVUNYQjd4dmJsWHJoVVlWQVN2SFo2YWJPanJsRkFWZk9SMm5lek0tWnF5d3h8C3AnYOPxO0flEwO6Ffoq9Tlqs1s&grant_type=authorization_code&redirect_uri=https%3A%2F%2Fmyapp.acme.com%2Foauth2redirect
Hope this will help
