Javascript SDK state for oAuth 2
  • February 16, 2021
  • 389 views
I would like to be able to send the state when I call LoginWindow. I can not find any documentation on the SDK. How do I pass in a state for the OAuth?
    RC.state = utils.uuid();
    var rcsdk = new RingCentral.SDK({
        server: RingCentral.SDK.server.sandbox,
        clientId: RC.RingCentralClientID ,
        clientSecret: RC.RingCentralClientSecret,
        redirectUri: RC.RingCentralRedirectURL, // optional, but is required for Implicit Grant and Authorization Code OAuth Flows (see below)
        state: RC.state
    console.log(RC.state);
    var loginUrl = rcsdk.loginUrl({implicit: false}); // implicit parameter is optional, default false
    console.log(loginUrl);
This does not work, st the URL does not have the state in it, or is it passed back to the Redirect URL.
  • February 16, 2021
You have to create an AuthorizeRequest object and call the rc.authorizeUri() method.
https://github.com/ringcentral/ringcentral-java/blob/master/src/main/java/com/ringcentral/RestClient.java#L322
https://github.com/ringcentral/ringcentral-java/blob/master/src/main/java/com/ringcentral/definitions/AuthorizeRequest.java
See the sample code on this quick start
https://developers.ringcentral.com/guide/authentication/quick-start#java
// Replace this
response.getWriter().println("<h2>RingCentral Authorization Code Flow Authentication</h2><a href="" + rc.authorizeUri(REDIRECT_URI) + "">Login RingCentral Account</a>");
// With this
response.getWriter().println("<h2>RingCentral Authorization Code Flow Authentication</h2><a href="" + rc.authorizeUri("Your-AuthorizeRequest-Object") + "">Login RingCentral Account</a>");
  • February 17, 2021
Phong, Thank you for the quick response. But these examples are in Java and I am not familiar with Java. Do you have the same in Javascript?
  • February 17, 2021
Oops, how come I saw it Java??? Too tired.
https://developers.ringcentral.com/guide/authentication/quick-start#javascript
app.get('/', async function(req, res) {
  var platform = rcsdk.platform()
  if (req.session.tokens != undefined) {
    platform.auth().setData(req.session.tokens)
    if (await platform.loggedIn()) {
      return res.render('test')
  } else {
    res.render('index', {
      authorize_uri: platform.loginUrl({
        redirectUri: RINGCENTRAL_REDIRECT_URL,
        state: "state string",
