Message Store Export C# Index does not contain definition for List
  • February 29, 2024
  • 199 views
I am trying to test out the Message Store Export (kinda new at this) and am running into some errors. I am using the code from the documentation here. I already replaced the depreciated WebClient with HTTP but am still getting this error:
Error CS1061 'Index' does not contain a definition for 'List' and no accessible extension method 'List' accepting a first argument of type 'Index' could be found (are you missing a using directive or an assembly reference?)
I do have the RingCentral SDK installed. Any help would be appreciated!
using System;
using System.IO;
using System.Net.Http;
using System.Threading.Tasks;
using RingCentral;
namespace Export_MessageStore
    class Program
        static RestClient restClient;
        static HttpClient httpClient = new HttpClient();
        static async Task Main(string[] args)
            try
                // Instantiate the SDK
                restClient = new RestClient("SANDBOX-APP-CLIENTID", "SANDBOX-APP-CLIENTSECRET", "https://platform.devtest.ringcentral.com");
                // Authenticate a user using a personal JWT token
                await restClient.Authorize("SANDBOX_JWT");
                await CreateMessageStoreReport();
            catch (Exception ex)
        static private async Task CreateMessageStoreReport()
            var bodyParams = new CreateMessageStoreReportRequest
                dateFrom = "2023-03-01T00:00:00.000Z",
                dateTo = "2023-03-31T23:59:59.999Z"
            var response = await restClient.Restapi().Account().MessageStoreReport().Post(bodyParams);
            await GetMessageStoreReportTask(response.id);
        static private async Task GetMessageStoreReportTask(string taskId)
            bool isCompleted = false;
            while (!isCompleted)
                var response = await restClient.Restapi().Account().MessageStoreReport(taskId).Get();
                Console.WriteLine("Task creation status: " + response.status);
                switch (response.status)
                    case "Completed":
                        isCompleted = true;
                        await GetMessageStoreReportArchive(taskId);
                        break;
                    case "AttemptFailed":
                    case "Failed":
                    case "Cancelled":
                        Console.WriteLine("Export message store failed.");
                        return;
                    default:
                        await Task.Delay(10000); // Use non-blocking delay
                        break;
        static private async Task GetMessageStoreReportArchive(string taskId)
            Console.WriteLine("Getting report uri ...");
            var resp = await restClient.Restapi().Account().MessageStoreReport(taskId).Archive().List();
            var dateStr = DateTime.Now.ToString("yyyy-MM-dd-HH_mm");
            for (var i = 0; i < resp.records.Length; i++)
                var fileName = $"message_store_content_{dateStr}_{i}.zip";
                var contentUrl = $"{resp.records[i].uri}?access_token={restClient.token.access_token}";
                // Use HttpClient for downloading the file
                var response = await httpClient.GetAsync(contentUrl);
                if (response.IsSuccessStatusCode)
                    using (var stream = await response.Content.ReadAsStreamAsync())
                    using (var fileStream = new FileStream(fileName, FileMode.Create, FileAccess.Write))
                        await stream.CopyToAsync(fileStream);
                    Console.WriteLine($"{fileName} file is saved to the local machine.");
                else
                    Console.WriteLine($"Failed to download file: {fileName}");
There was a change and it causes the mistake in the sample code. Please modify the code in this function. Change List() to Get().
static private async Task get_message_store_report_archive(String taskId)
    var resp = await restClient.Restapi().Account().MessageStoreReport(taskId).Archive().Get();
    DateTime value = DateTime.Now;
I will update the sample code soon.
aburgessThe First StepAuthor
For some reason when I filter to SMS, I get nothing. I can Read_MessageStore and filter it to SMS and that come out okay. When I filter this line of code (with your awesome fix), nothing comes up when it is outputted. Is filtering not able to be used when exporting?
                dateFrom = "2024-03-01T12:00:00.000Z",
                dateTo = "2024-03-01T13:00:00.000Z",
                messageTypes = new[] {"SMS"}
                    case "Completed":
                        isCompleted = true;
                        break;
                    case "Failed":
                    case "Cancelled":
                        return;
                    default:
                        break;
