Missed call notification not working
  • February 2, 2021
  • 1449 views
Hello,
I am trying to set up a webhook notification for missed inbound calls. I'm using the following event filter for that purpose:
/restapi/v1.0/account/~/extension/{extensionId}/telephony/sessions?direction=Inbound&missedCall=true
However, whenever there's a missed inbound call, I get no notifications whatsoever.
If I remove the missedCall=true parameter, I get 3 notifications for every missed call:
  1. The call "Setup" notification (where missedCall = false)
  2. The "Voicemail" notification (where missedCall = false)
  3. The "Disconnected" notification (where missedCall = true)
If I set the missedCall=false parameter, I get the first 2 notifications, which leads me to think that there's something wrong with the RingCentral notifications when it comes to missed calls in particular.
Any ideas?
  • February 2, 2021
You are using the extension level "/restapi/v1.0/account/~/extension/{extensionId}/", are you sure that you made a call to one of the phone numbers of that extension?
Can you try the account level and run your test?
/restapi/v1.0/account/~/telephony/sessions?direction=Inbound&missedCall=true
  • February 3, 2021
The extension ID is correct I assume, since I'm getting all the other extension-specific notifications.
When I subscribe to the account-level notification instead, I do get the notification, but I'm not able to specify which extension to monitor.
So to summarize, this is my experience:
  • The extension ID is the correct one (I'm getting all the notifications for that extension when specifying the extension ID)
  • The missedCall=true filter works only at the account-level notifications
  • February 3, 2021
To add more information, here's the event I received when the subscription was set at the account level:
I then changed the subscription to receive events at the extension level, using the same extension ID as above:
And after that, I stopped receiving the notifications.
  • February 3, 2021
I asked you are you sure the incoming call was dialed to a phone number belong to that extension (id: 287893004)?
I tested on my account and I got it works for both account level and extension level. Pls double check the phone number.
