no authorization code is returned when authenticating using oauth
  • November 28, 2017
  • 2339 views
After oauth, no code is returned to redirect URL. i do not get any error in my server log too.
I doubt whether my app is not enabled for that country? or any other issue?
Could you please provide us with more detail?  If there is not code returned to redirect URL, could you please post the whole redirect URL here?  Or you can post some code snippets for us to analyze.
Make sure you use correct format in Authorize url.
Also try putting following and check you are getting the code back in the url
response_type=code
It would have been better if you had provided your format here to get verified
