Queries for active calls every 5 seconds only works for 5 times
  • April 20, 2023
  • 218 views
I have a php page that queries for active calls every 5 seconds. I want to get incoming calls and updating my database with existing calls, whether it was answered/missed, how long the call was ect. It works great for 10 queries then will not allow further queries until after a time has passed. I am assuming there is a limit to the number of queries allowed. I am in sandbox mode. Will this limit change when the App goes into production mode? Is there a way to automatically open a url when a call comes in on rings end. Any help would be appreciated.
  • April 20, 2023
The usage group of that API (I assumed you are talking about this API) is Heavy which means the rate limit is 10 times per 60 secs. So calling the API every 5 secs will hit the rate limit for sure. And will be the same limit on the production environment.
However, for such use case, you should not poll but use one of the notification filters to get notified when there is an incoming call, the call is answered or not then the call is disconnected.
If you don't need lots of data, you can use the presence event notification with the filter "/presence?detailedTelephonyState=true"
If you need lot more data and different call statuses, use the telephony session even notification filter.
Read this blog and this blog for further information about telephony session event notifications and some use cases.
