Receiving events from PubNub without SDK
  • July 15, 2020
  • 1106 views
Hello,
I am developing in a sandboxed c# environment which will not allow me to use either the RingCentral or PubNub SDKs.
I am able to make calls from my softphone and have used the create subscription command successfully, it returns the sub_key, address, etc.
I am struggling with how to receive those events from PubNub. The documentation I have found on your site references using this command to subscribe for notifications: GET http://pubsub.pubnub.com/subscribe/{subscriberKey}/{address}/{callback}/{timetoken} . Although I had to due a lot of digging, my understanding is that request should open a sustained connection which will push the notifications to me.
That command is referenced on their site: https://www.pubnub.com/docs/pubnub-rest-api-documentation#publish-subscribe-subscribe-get
I have had no success with that subscribe request with my program, curl, or postman.
Documentation outside of the SDK's is very limited. Can you please help.
Thanks,
Owain Price
  • July 15, 2020
Can you look at the code how the RingCentral SDK implement PubNub notification and do the same?
I have already had a look at that code. Unfortunately you are utilizing the PubNub SDK which I cannot.
Your developer site does reference an alternative method which is described at the very bottom of this page:
https://developers.ringcentral.com/guide/notifications/manual/pubnub
It uses the PubNub REST API. Are you familiar with that? I cannot seem to make it work.
Thank you
Bump
@Phong Vu any other recommendations?
I need to be able to receive these notifications without using either sdk.
