Redtail CRM Ring Central Integration for Edge browser
  • 16 July 2020
  • 1128 views
I have added and am using the beta integration for RC and Redtail CRM for Chrome. Will this same file work on Edge? If not, is there a way to utilize this integration on Edge?
As per the reference here: https://www.ringcentral.com/apps/redtail-crm Chrome/Firefox browser is mentioned
Also here: https://ringcentral.github.io/redtail-embeddable-ringcentral-phone/
Previously, there was discussion on RingCentral supported browsers which says officially support Google Chrome browser
for your reference: https://forums.developers.ringcentral.com/questions/8984/ring-central-webphone-implementation-doesnt-work-i.html
