ringout.asp behaving differently starting around 13th of February
  • February 20, 2018
  • 273 views
doing an http post to the ringout.asp page used to ring the extension of the caller (internal) they would pick up and then the system would ring the callee (external). Starting last Monday the 13th, it now calls the callee then rings the caller. Doing the process backward and the callee sits on the phone in silence while the system rings the internal caller. Makes no sense. Anyone else experiencing this? Have you found a work around? RingCentral knows about this issue - but I need a fix ASAP - our outbound call productivity is way down since this change happened.
  • February 20, 2018
Hi Brian,
Thanks for your report! We have received similar reports from other developers and our platform engineers are investigating the problem. They will fix it as soon as they can and I will update you when I hear more from the team.
Stay tuned.
+ Phong
