Sending Fax problem
  • July 10, 2017
  • 3369 views
After getting access token when i try to send Test fax it is showing error, I need help
here is my code for sending fax
if ($platform->loggedIn()){
$request = $rcsdk->createMultipartBuilder()
->setBody(array(
'to' => array(
array('phoneNumber' => '12673314004'),
'faxResolution' => 'High',
->request('/account/~/extension/~/fax');
$response = $platform->sendRequest($request);
and here is the Error
  • July 10, 2017
Tayyab,
Per the error description "Token Not Found" it looks like you are not using the token to make the API call ( Fax API Endpoint
For more guidance, you can take a look at the demo inside of our Official PHP SDK:
https://github.com/ringcentral/ringcentral-php
Have you tried using the Demo under the SDK ?
  • July 11, 2017
i am using Web app, so after 3-Legged OAuth access token , i am not sure how to use that token and in https://github.com/ringcentral/ringcentral-php there is no help to use token .
Right now i am stuck at this point.
