System.ValueTuple error when sending/receiving fax
  • October 2, 2019
  • 572 views
My application throws "Could not load file or assembly 'System.ValueTuple, Version=4.0.2.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51' or one of its dependencies" whenever I try to send or retrieve a fax message. I am stumped and need help ASAP.
The interesting part is, the application runs fine on localhost. It fails when it is deployed on a server.
Best answer by PhongVu
It seems to be a conflict in .Net Framework in your app. You may find a solution from here.
https://stackoverflow.com/questions/42867434/could-not-load-file-or-assembly-system-valuetuple/50636962
  • October 2, 2019
