Using WebHook for notification of login / logout
  • June 30, 2020
  • 843 views
I have set up webhooks and I am receiving almost everything I need, call activity, presence, webhook expiry etc
But.. I dont seem to be able to get a notification of when a RingCentral Softphone Logout or Login happens.. what do I need to be subscribing to in order to receive that notification
Best answer by PhongVu
Unfortunately, there is no event about user login/logout. I am thinking of some workaround solution but cannot find one either.
  • June 30, 2020
  • July 1, 2020
Thanks Phong
In that case I will need to implement some kind of Extension List polling
I think it would be something important to add to the Webhook
