Webhook Issue
  • November 1, 2021
  • 10 replies
  • 1075 views
My webhook is no longer receiving anything from RingCentral, it's been working for 1.5 years...
Things I've tried:
- Creating a new webhook
- Verifying the webhook exists using "Get Subscriptions" (https://developers.ringcentral.com/api-reference/Subscriptions/listSubscriptions)
- Verified the server address is accurate when creating the webhook
- Verified I can talk to my webhook server over the internet and that it see's me doing so
- Updated all libraries that are being used in my scripts
Any ideas? Seems like it stopped working this weekend, but it might have been longer than that, I just noticed this morning.
I'm using Python, NGROK, WSGI and Flask. Like I said though, this has been working so not sure if it's related to a bigger issue.
Best answer by PhongVu
What event filters are in your subscription?
  • November 1, 2021
I'm experiencing the same issue.
  • November 1, 2021
  • Found Your Voice
  • November 1, 2021
Hey Phong,
I'm using: /restapi/v1.0/account/~/telephony/sessions
  • November 2, 2021
The intermittent subscription issue that we had yesterday has been resolved completely. Please confirm your instance works fine.
  • November 2, 2021
Was working for me after the fix and in the last hour it stopped again.
  • November 2, 2021
We have not heard from others since the fixes. Can you double check by delete all existing subscriptions (if any) then create a new one. If the problem persists, give me your account id.
  • Found Your Voice
  • November 3, 2021
Sorry for the delay. Yes, it's been working for me.
Thank you!
  • November 3, 2021
Looks like there was an intermittent issue again this morning for a short period and the issue issue got resolved as well. Should be working correctly.
  • November 4, 2021
Still not working for me
recreated the subscription, new id is aa0b7463-e3d6-4301-abb0-1113e5bd3bca
  • November 4, 2021
@Gary Can you open a support ticket or reach out to me via email vyshakh.babji@ringcentral.com . I can help you in getting this resolved.
