What is the best method to forward calls to other internal numbers?
  • April 19, 2019
  • 1786 views
My scenario: I need to forward calls coming in from certain 800#s to other internal numbers (ring groups) using custom routing logic.
What is the best method to use in my case? The Forward or Transfer method?
Additionally, both of those methods are marked under the Light usage plan. These 800#s will be called frequently and it's possible the Light usage plan might not allow enough calls to go through at peak times. What method should I use to route calls for this scenario?
  • April 19, 2019
BTW, when I try the Forward method I get an error (although the forward does actually take place):
RingCentral.RestException: 'Response:
StatusCode: 403, ReasonPhrase: 'Forbidden', Version: 1.1, Content: System.Net.Http.StreamContent, Headers:
  Connection: keep-alive
  X-Rate-Limit-Group: light
  X-Rate-Limit-Limit: 50
  X-Rate-Limit-Remaining: 49
  X-Rate-Limit-Window: 60
  Date: Fri, 19 Apr 2019 19:37:38 GMT
  Server: nginx
  Content-Length: 123
Content: {
   "errors" : [
         "errorCode" : "TAS-106",
         "message" : "Operation is not allowed"
  • April 19, 2019
Hi Tim,
My understanding is that:
Forward = Is used in the case of a call is directly redirected to another number before the call was answered. Think about those forwarding rules.
Transfer:
1. Warm transfer is when a call was picked up and the agent calls another number then connects the call.
2. Blind transfer is when the case a call was picked up by an agent and the agent just transfers the call to another number w/o knowing if that number is available.
Regarding the rate limit, just test your app and graduate it then submit a support ticket for increasing the rate limit with your business justification. Our support engineers will evaluate your case and grant a higher rate accordingly.
  • April 22, 2019
Thanks. What about the error I provided in my second reply? The forward does seem to actually work, but the exception is thrown regardless.
