John Wang avatar image
John Wang asked benjamin-dean answered
Notice - Intermittent OAuth Authorization Code Issues
Overview
We have identified an intermittent issue with OAuth authorization code grant where exchanging an authorization code for an access token may temporarily fail due to a synchronization issue. This is being resolved by our engineering team and we will provide an update here when it is available.
Temporary Workaround
A temporary workaround is to retry the authorization code exchange within your application. This needs to be done before the authorization code expires with a recommended delay of 3 seconds.
oauth
1 |3000
textus-services3431 avatar image
textus-services3431 answered
What did you do if the authorization code is already expired? Thanks John!
1 |3000
benjamin-dean avatar image
As part of this workaround, provided the authorization code trade request for a token is executed within three seconds, hopefully the authorization code is still valid.
If it is expired, I would recommend shortening the retry-delay to 2 seconds and see if that resolves the issue.
If that does not work, the appropriate authorization flow would be to consider the authentication attempt as failed, and to re-initialize the process for the end user (you could notify the user "we had a problem processing your authentication, please try again").
1 |3000
Quick update for developers, we have began rolling out the fix to this solution in specific environments, and will continue until this rollout is scheduled to be completed on November 7th.
If your application begins experiencing any issues related to this topic during this phased rollout, please post those issues here with as much detail as possible (making sure to remove any sensitive information such as API keys, API secrets, etc...).
1 |3000
Developer sandbox tools
