SMS API "Feature not available"
  • January 22, 2021
  • 16 replies
  • 1962 views
I created a new sandbox account for testing the SMS API. I then created a console app (per ringcentral instructions) and tested the API using the sand box credentials. Connecting to the API works fine but returns this error when trying to send a test SMS:
Content: {
"errorCode" : "FeatureNotAvailable",
"message" : "The requested feature is not available",
"errors" : [ {
"errorCode" : "MSG-242",
I have made sure I've added the correct features to the sandbox app (per the instructions) but it appears it is not setting the SMS feature to true.
This is a problem with the SANDBOX app, I haven't made it to production due to the fact I can't send an SMS in the sandbox app.
Thanks in advance.
Best answer by PhongVu
This problem should not happen as we fixed the process to include SMS feature to a sandbox main company number. I am not sure why it still happens time to time. Give me your sandbox main company number so I can ask the team to enable it manually for you.
Are you connecting to the sandbox phonenumber (vs your live RC phonenumber)?
PhongVuAnswer
Participating Frequently
January 22, 2021
I am having the exact same issue. I am using the Sandbox phone number. I cannot connect to support either...keep getting an Error page. Also, I cannot seem to locate any information as it pertains to `Path Params->accountId` or `Path Params->extensionId` really frustrating.
January 22, 2021
+14242543150
January 22, 2021
The `country` object returns errors as well.
January 22, 2021
January 22, 2021
Are the `accountId` and `extensionId` the same as the Username and Extension listed under `User Account Credentials`?
+14242543819
Yes, I'm using the sandbox credentials, not production or RC numbers. (userId, extension, key, secret)
Normally the extensionId of the first user (the Super Admin created by default) is the same as accountId.
