Call Handling Ring For settings
  • 19 May 2021
  • 240 views
So this is odd. Why do the mobile and desktop apps ignore the Ring For setting when it's set for less than 3 rings? If I set it for 1/5 they still ring for 3/15. The Always ring 30 setting doesn't seem to make much difference here.
Worse, if the user has a physical phone then there's a 20-ish second delay in the physical phone ringing UNLESS I set the Desktop & Mobile to 0/0.
Userlevel 4
Badge
Hi John, this is currently a normal behavior with the call forwarding settings on the app. Fell free to add your suggestions or ideas in our
Ideas Portal at https://ideas.ringcentral.com/
