Hello. I'm having a few problems and am seeking assistance.
  • 16 March 2019
  • 185 views
my first problem is when a call goes to voicemail it doesn't go to the ring central voicemail it goes to an individuals voicemail. my second problem is that the calls shouldn't come up as answered if no one answered them. and my last problem is when the call is forwarded it should go to the next person in the que not to voicemail.
the account type is through the ring central app in the USA. 2 users affected.
Let's deal with each issue individually.
(1) "when a call goes to voicemail it doesn't go to the ring central voicemail it goes to an individuals voicemail."
So when you say 'individuals voicemail' do you mean their cell phone VM?
Thomas,did you get your issues resolved?
Chuck
Certified Ring Central Consultant
