Hoping the community has insight as the lack of support with Ring Central is approaching legendary status. Essentially, we already have TCR brand approval AND a campaign approval. We then launched a customer outreach using Ring Central Labs Enhanced Business SMS. From ~ 1:11pm to 2pm it was fine and then every single text was unable to be sent. We paused the outreach and that's of course where the Ring Central customer service fails. After ridiculous "guesses" by tech support (which means they really have no idea) we are still waiting. This outreach needs to get out as it is a contractual requirement for the company so hoping someone on here has had a similar issue and can provide some insight.
Need Help: Enhanced Business SMS Stalled/Not Working - RC no Help and Hung up
Can you join the app support team by clicking the icon on the bottom right corner in the app and @mention me from that team so I can help you with.
@Phong Vu can you just IM me or provide a bit better direction as that icon does not exist on our desktop app nor inside the web version?
You mentioned this "Ring Central Labs Enhanced Business SMS" so I thought that you are using the SMS-Campaigns app, do you?
Correct but it will not allow us to join the chat. Acts like we need an invite?
"Cannot add this user to the support team. Please try again"
Yes correct same email thx
This is from your side. I cannot add you nor can I DM you
Sorry, your invite(s) wasn't sent because the recipients' company admin has blocked external invites.
changing now
external guest communication is toggled on?
