Poly Vxx 150 and 250 no phone manual just a quick reference guide. Trying to hook it up t my pc since I dont have a wall jack on this floor. Anyone know how to do this and update the phone date time etc? It might have been a good point to make that a wall jack or router be near by for this type of phone to be set up.
Page 1 / 1
Is your computer using wifi or is it hard wired? If it's hard wired you can run the cable to the phone first plugging into the LAN port and then run another ethernet cable (should have came with the phone) to the PC.
