Call Queue Members Unavailable and Calls Not Immediately Going to Voicemail
  • August 25, 2022
  • 1433 views
We have a call queue for our main knowledge center. The call queue manager reported an issue wherein all callers are unavailable during business hours and a call will not automatically go to voicemail. The queue is set up to wait for a given time before going to voicemail. There is no option for a caller to be sent right to voicemail with a different message (all agents are busy, if you'd like to leave a voicemail press 1). But we have a recording of this message that we've put into the call queue previously that say this, but not the option is no longer there.
The call queue manager has said something has changed in the past few weeks. I have a ticket open with RC and they say that's never been an option. I'm trying not to pass judgement on either side, but I know this person and they are kind of a stickler for how their call center runs. Is it possible there WAS a change and the RC tech doesn't know that? Is there a setting we're missing?
  • June 21, 2023
I would also like to know the answer to this. No matter what I try, I can't seem to get calls to NOT ring when all members are busy/away.
I think I figured this out. Inside the RC Admin menu when you check the call queue settings for Call Handling & Members > Wait settings > When members are available, but no members answer or all members are busy or unavailable. It gives a drop down menu like there would be more than one option but there is only the option for callers to wait. I'm assuming at one point there was an option to play a message or to send to voicemail but it is no longer there. It doesn't look like there is anything we can do about this.
