How to turn off Ring Out and Turn on Direct
  • July 18, 2018
  • 9 replies
  • 1222 views
I am in outgoing calls on my computer app. Recently the app switched on the RingOut feature auto magically. I go in to the setting to direct dial and that feature is no longer there. How can I get it back?
  • July 18, 2018
I am on 10.1.2  I log in using my email which is linked to my direct number.
  • Known Participant
  • July 18, 2018
Hmm....what happens when you log in with your direct number?
  • July 18, 2018
From the admin screen I had to deactivate the account and reactivate the account. Now it works!
  • Known Participant
  • July 18, 2018
Weird! It must have gotten stuck on the back end or something. Glad it's working now!
  • August 14, 2018
this has happened to 3 different users for us. Might be worth looking into as we haven't found a resolution yet.
Any update on this? The same issue
  • May 5, 2020
Also having same issue, some devices using the same line can switch, others cannot
  • Known Participant
  • July 30, 2020
Hey l.olson,
What version of the softphone are you on? How do you log into your extension? With a direct number or the main company number + your extension?
Can confirm that disabling the account for a moment resolved this issue today on version 24.3.0.47527
