Some calls are not coming through. We need help finding out why.
  • March 16, 2020
  • 417 views
some customers get a continuous busy signal or a simple message that the call cannot be completed at this time.
  • March 16, 2020
Hi Mik,
From your description it sounds like their might be a carrier related issue either on the RingCentral side or with an intermediary or terminating carrier. Basically there might be a road block or traffic jam and traffic might need to be detoured.
The best course of action will be to Open a RingCentral Tech Support Case
For these types of issues we would want to see 2-4 detailed call examples (template below) from the last 24 hours, we can investigate those calls and see where a re-route or other fix may be needed:
Call Example 1:
Number (From):
Number (To):
Date: 2020-03-16
Time+Timezone:
Result: Heard announcement  that the call cannot be completed at this time.
Call Example 2:
Number (From):
Number (To):
Date: 2020-03-16
Time+Timezone:
Call Example 3:
Number (From):
Number (To):
Date: 2020-03-16
Time+Timezone:
  • March 16, 2020
Why?  Possibly because everyone that can suddenly started working from home.  It is putting a huge strain on every provider and every carrier.
