Loading Call Analytics Data into Power BI
  • 30 January 2023
  • 691 views
I am a new data engineer trying to set up integration of RingCentral analytics data into Power BI using this article:
Suyash Joshi
answered Apr 19 2022 at 10:23 AM
Check this blog out that shows how to get data from RingCentral Analytics API to Microsoft Power BI using Azure: https://medium.com/ringcentral-developers/low-code-integration-of-ringcentral-analytics-api-with-microsoft-azure-power-bi-2a400fa7a15f
However I am struggling with the details of actually putting together the pipeline. I am not sure what link to use to get the credentials in step #1 and not sure how to set up step #2. Does anyone have a more detailed step-by-step process to get this pipeline set up?
@Suyash Joshi
Thanks!
Userlevel 2
Badge
I am not an expert in Power BI so I cannot help at the code level. But RingCentral API platform is a REST API platform so you can use an HTTP client to call the APIs. You first need to authenticate a user and get the access token, then use the access token to call other APIs.
Maybe this YouTube video could help you get started.
