DTMF tones not being sent to destination. Why not?
  • 31 August 2023
  • 257 views
For some time now, we've noticed users experiencing issues transferring/conferencing clients with destinations that have an IVR out front.
Significantly often, the call is completed to the destination but during interactivity with that IVR our users can enter whatever number they wish but the tones aren't being sent to the recipient.
I've noticed in the forums here this has been an issue for about 2 years now.
here and here as an example. Both threads trail off into nothing with no explanation or resolution. I've looked to see if this was resolved elsewhere somehow in the community/documentation but I can't find nothing.
As it appears that my org isn't the only one experiencing it, I'm living in hope that someone else found the solution.
This is not something that can be resolved in here. Your best chance is to contact support and you might want to prepare some example calls like
Caller:
Callee:
Date & time:
Call Flow in detail (including what keys the agent pressed and what happened):
And if this is trickier than expected, you want to be writing down example calls, even after you have reported the issue, since support might need more data to figure it out.
