How to restrict fax from getting incoming fax. We just want to use outgoing fax messages and want to restrict the incoming ones. What set up we need to make?
Restrict incoming fax and allowing outgoing
Try by turning off "take messages" option under message section in online portal :
ref: https://community.ringcentral.com/questions/28614/disable-incoming-faxes-during-holidays.html
