Huron5315
Just got a new cisco 8861 phone.  I have a direct internet connection.  It is asking for an activation code and there is none.  Please let me know the work around.
Problem Solver
  • 118 replies
  • April 7, 2025
it is asking for an activation code because something is not right. If you bought the phone from RC it should automatically register - you should see the phone do an update and then go online, without you having to enter an activation code.
I am assuming you double checked everything on the portal:
1. the phone is assigned to a user.
2. the user is enabled
3. both the phone type and the Serial number are visible when you go to Phone System > Phones & Devices > User phones)
If you bought the phone from a third party - you need to provision it.
If you bought the phone from RC - there is a network issue and you need to check the network requirements.
  • April 7, 2025
Bought from Amazon
Problem Solver
  • 118 replies
  • April 8, 2025
go to RC admin portal > Phone system > Phones & devices > click on the user ext > check what device is assigned
- it should be cisco 8861 with Serial number xxxxxxxxxxx. If the device model or serial number is missing, that’s an issue.
- If you have rc app assigned to your user click on “Change phone”> Bring your own device
