Authentication The [Audience] claim value must contain a token endpoint URL | Node SDK
I have a basic Node app and having issues authenticating. I have set my server, clientId, secretId and jwt. However, I keep getting this error
My code looks like:
const RC_SDK = require('@ringcentral/sdk').SDK
const path = require('path')
require('dotenv').config({ path: path.resolve(__dirname, './.env') })
var rcsdk = new RC_SDK({
    'server':       process.env.RC_SERVER_URL,
    'clientId':     process.env.RC_CLIENT_ID,
    'clientSecret': process.env.RC_CLIENT_SECRET
var platform = rcsdk.platform();
platform.login({ 'jwt':  process.env.RC_JWT })
platform.on(platform.events.loginSuccess, function(e){
    console.log('LOGGED IN')
platform.on(platform.events.loginError, function(e){
    console.log("Unable to authenticate to platform. Check credentials.", e.message)
    process.exit(1)
Best answer by PhongVu
tony.gamble wrote:
oh, the client id is:
AV0pSJy794tfaI6pRp6wfr
I see that you have 2 JWT tokens for all apps under your organization. One JWT is for sandbox and another is for production. Can you double check if you are using the right one. Since you set the server for the production server: 'https://platform.ringcentral.com', make sure that you use the JWT for production. Otherwise, change the server to https://platform.devtest.ringcentral.com'  and try again.
View original
  • August 1, 2024
I don’t see anything wrong with the code. Can you print out the params you load from the .env file and check if they are all load/read correctly (for your investigation only. Don’t need to share those here!)
E.g.
console.log(process.env.RC_CLIENT_ID)
console.log(process.env.RC_JWT)
yes, the env variables are being loaded as expected:
  clientId: 'XXXXXXXX',
  clientSecret: 'XXXXXXXX',
  jwt: 'eyJraWQi...'
  • August 2, 2024
  jwt: 'eyJraWQi...'
Then give me the app client id
Yes, I have given the clientId and clientSecret, the above is just not to expose my ids. I still have the same issue
  • August 2, 2024
What do you mean? I ask you to post the app client id here so I can check the app settings
  • August 3, 2024
Thanks, this fixed the issue!
