Create webhook for receiving calls using Javascript sdk
  • December 11, 2017
  • 922 views
HI all try create webhook for receiving calls using javascript sdk, but i got Error: Parameter [request] value is invalid
This is my following code
 var _eventFilters = [];
        _eventFilters.push('/restapi/v1.0/account/~/extension/' + 101 + '/presence?detailedTelephonyState=true&aggregated=true')
  rcsdk.platform()
            .send({
                method: 'POST',                  url: '/subscription',                  eventFilters: _eventFilters,                  deliveryMode: {                      "transportType": "WebHook",                      "encryption": false,                      "address": "https://33d7f758.ngrok.io/RingCentralTest/RcTest";                  }              })              .then(function (apiResponse) {                  console.log(apiResponse.json())                })              .catch(function (e) {                    console.log(e)              });
Thanks in Advance
  • December 11, 2017
Hi Robert,
The event filters that you have passed for creating the subscription via WebHook is wrong.
Kindly use the below code and try the API call again:
        _eventFilters.push('/restapi/v1.0/account/~/extension/~/presence?detailedTelephonyState=true&aggregated=true')
When you pass the event filters for an extension you can either provide :
1.) (~) which would refer to the extension authorized by.
2.) Provide the extensionID for an extension, which you can look up using the below API Endpoint
      Get Extensions List
      GET /v1.0/account/{accountId}/extension/
101 is extension number. Extension ID is expected.
  • December 12, 2017
After applying the extension id getting the error
    at Client.<anonymous> (/var/www/html/commusoft-app/node_modules/ringcentral/src/http/Client.js:62)
    at <anonymous>
