How do I get the voicemail transcription from a Group using C#
  • July 18, 2023
  • 574 views
First I am unable to get even my own personal voicemail transcriptions using this method. It find the transcription record but I can't see any parameters with the transcription string.
Second how will I change this to access a Group's voicemail transcription?
Thanks.
using System;
using System.Threading.Tasks;
using RingCentral;
namespace Account
    class Account
        static String SERVER_URL = "https://platform.ringcentral.com";
        static String CLIENT_ID = "************";
        static String CLIENT_SECRET = "********";
        static String JWT_TOKEN = "************";
        static RestClient restClient;
            restClient = new RestClient(CLIENT_ID, CLIENT_SECRET, true, "VoiceMailTranscriptionGet");
            restClient.Authorize(JWT_TOKEN).Wait();
            GetMessage().Wait();
        static private async Task GetMessage()
            ListMessagesParameters parameters = new ListMessagesParameters();
            parameters.messageType = new String[] { "VoiceMail" };
            var response = await restClient.Restapi().Account().Extension().MessageStore().List(parameters);
            foreach (GetMessageInfoResponse record in response.records)
                if (record.attachments != null)
                    foreach (var attachment in record.attachments)
                        var fileName = "./src/test/resources/" + record.attachments[0].id + "_voicemail.txt";
                        if (attachment.type == "AudioTranscription")
                            var res = restClient.Restapi().Account().Extension().MessageStore(record.id.ToString()).Content(attachment.id.ToString()).Get();
                            //Path path = Paths.get(fileName);
                            //Files.write(path, res);
  • July 18, 2023
  • July 19, 2023
First of all, you have to make sure also the voicemail transcription is Completed
if (attachment.type == "AudioTranscription" &&
                                         record.vmTranscriptionStatus == "Completed")
    var res = await restClient.Restapi().Account().Extension().MessageStore(record.id.ToString()).Content(attachment.id.ToString()).Get();
    using (BinaryWriter writer = new BinaryWriter(System.IO.File.Open(path + fileName, FileMode.Create)))
        writer.Write(res);
        writer.Flush();
        writer.Close();
If you need to access and download a message store content (e.g. voicemail) of another user extension, including a group's voicemail (call queue), you must authenticate your app with a super admin user, and specify the extension id in the path as shown in the example below:
var EXTENSION_ID = "12345678890";
var resp = await restClient.Restapi().Account().Extension(EXTENSION_ID).MessageStore().List(parameters);
foreach (var record in resp.records)
    var res = await restClient.Restapi().Account().Extension(EXTENSION_ID).MessageStore(record.id.ToString()).Content(attachment.id.ToString()).Get();
  • July 19, 2023
I added the EXTENSION_ID var and valued it to 9000, now I get "Resource for parameter [extensionId] is not found"
this is for a call queue group with an extension of 9000
